-   -   centrifugal pump cfd analysis (http://www.cfd-online.com/Forums/fluent/32456-centrifugal-pump-cfd-analysis.html)
shatruhan lal November 6, 2003 06:20
Respected members, I am a m tech student in iit delhi.I made the geomtry of centrifugal pump and meshed, when I apply all conditions then it gives result for air only . when I run for water then the continuity goes upwards.i m facing problem,please suggest me why I am not getting result for water. which model should I use, and other related conditions so that i can get result.can you provide any references done in for the above problem.
Ahmet November 6, 2003 07:23
Re: centrifugal pump cfd analysis
Did you define all domains as water?
Ahmet
