December 16, 2023, 17:26 |
High turbulent viscosity & Discete Phase
Luca
Rep Power: 5 |
Hi everyone, I am trying to simulate a fluid flow composed by a mixture of h2o, o2 and n2 at high temperature which needs to be cooled down by water injection, modeled through droplets exploiting DPM. Once I run the model the calculation proceeds, but at every iteration Fluent reports "turbulent viscosity limited to viscosity ratio of 1e+05", for the entire domain. From what I observed, this usually happens due to poor initialization (therefore only for first iterations) or completely wrong BC at inlets for turbulence, but I am quite sure this is not the case. I state that I am not so skilled in DPM, is there anyone who has already experienced this issue? Thanks!
Multiphase non-Newtonian viscosity of blood | mdmtramper | Fluent Multiphase | 3 | January 22, 2021 06:09 |
Drag Force Ratio for Flat Plate | Rob Wilk | Main CFD Forum | 40 | May 10, 2020 04:47 |
Identifying cells having Turbulent viscosity limited to viscosity ratio of 1.000e+05 | Sayantan Biswas | FLUENT | 0 | September 20, 2019 04:49 |
High turbulent viscosity, problem with BC | Narmin | FLUENT | 2 | May 8, 2007 03:17 |
Turbulent viscosity in a riser | ap | FLUENT | 8 | April 19, 2003 08:00 |
