UDF file for defining density as fn of pressure
Old   October 7, 2003, 07:30
Default UDF file for defining density as fn of pressure
anton
Hi all
Does anyone have a UDF where I can define the density as a function of pressure. I need to make water compressible
Thanks
Old   October 7, 2003, 08:04
Default Re: UDF file for defining density as fn of pressur
mateus
Hi!
It should look pretty much the same as the UDF that relates density to temerature (look in UDF manual - examples/tutorial). But I'm not shure if fluent allows this kind of relation. I've tried to do this for cavitation simulation but it did't work. Maybe you'll have better luck since you probabilly don't have so significant changes in density...
regards
MATEUS
Old   October 8, 2003, 02:35
Philipp Beierer
I guess it could look something like:
DEFINE_PROPERTY(cell_density,cell,thread)
real density;
real pressure = C_P(cell,thread);
if( pressure > 1E-08 ) // to ensure that you have only positive pressure values
density = "your function";
else
density = "your lowest value (of course, previous function should be continuous)";
return density;
Philipp
Old   October 10, 2003, 10:09
mateus
Hi!
I found this sentance in Fluent documentation... "density (as a function of temperature only)", but i'm not totally convinsed that it's impossible...
REGARDS
mateus
Old   October 13, 2003, 03:14
Alexandre
I had the same problem.
The Fluent support team said : "it cannot be done".
Unfortunately the density cannot be given as a function of pressure.
regards
Alexandre
Old   October 16, 2003, 03:18
Philipp Beierer
...never say never. Have you tried yourself or did you just ask the "support team"?
I agree that you face some problems when you have large density variations in situ. However, if these are relatively minor, it should work. I'm saying this as I was actually able to successfully model a liquid with a desity variation of about 5%.
Regards Philipp
Old   October 16, 2003, 03:22
Alexandre
you're right ...
... but I tried to add a covolume term to the ideal gas law and it failed.
I must agree that my case was totally different from yours. After this failure I asked the support.
Old   October 16, 2003, 04:04
raluca
Hi, once I tried to define the density as un udf and I assure you that it doesn't work. More than this I asked Fluent support from France and they know that it is impossible. Try to write your density as an udf and to rewrite your equation as an udf. Good luck.
Old   November 11, 2003, 09:59
anton
Hi Philipp
This sounds like exactly what I want to do (compress water with a 5% density variation)
How did you do this....did you add your own udf?
Thanks in advance
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
Fluent 5.2, UDF and Pressure BC's Alfonso Ferrandez FLUENT 0 May 4, 2000 07:02
