RNG
Old   November 22, 2003, 03:05
Default RNG
akbar
hi
I have a problem with RNG k-epsilon turbulence model.
I want to simulate 3-D Pattern of flow at a lateral intake in straight open channel.When I use RNG turbulence Model I can't converge the solution (I use the difrential viscosity and Swirl... options). can everybody help me? thanks
Old   November 23, 2003, 23:55
Default Re: RNG
ROOZBEH
Hi;
Chek Y+ on the walls. Its value should not bellow 30 and should between 30 to 200. Use the differential viscosity model if in your case the low Reynolds number effects is considerable.
Hope this help you
ROOZBEH
RNG k-epsilon model implementation romant OpenFOAM Running, Solving & CFD 2 June 20, 2018 08:33
why RNG k-e is better & what does RNG really mean? Bonnie White FLUENT 1 August 8, 2006 09:14
HELP!! Prandtl numbers in RNG k-e turbulence model maoasis FLUENT 0 April 24, 2006 10:51
rng les zxaar FLUENT 0 May 18, 2005 01:16
RNG with Schemit number zwdi FLUENT 0 August 2, 2004 11:54
