grid dependency
Old   November 11, 2003, 06:56
Default grid dependency
levo
Hi, I'm running 2D incompressible viscous analysis on some airfoils; I'm using a kwsst model with boundary layer solution (Y+<1), second order interpolation schemes for all the variable and steady segregated implicit solver. Every time I try a new grid I obtain different results. Is there anybody that could suggest me a good grid or some grid convergence criteria? Does anybody notice some better turbolence model? Thanks
Old   November 11, 2003, 09:11
Default Re: grid dependency
ap
If you want to obtain a grid independend solution, you have to refine it till results will not change anymore changing the grid.
Hi
ap
Old   November 11, 2003, 09:27
mateus
Hi!
Do you use structured mesh? You should obtain beter results (or the same but faster) with structured C or O type mesh...
MATEUS
Old   November 11, 2003, 09:35
levo
Thaks ap for your answer. Do you mean hanging node adaption based on velocity gradients? I've already done it starting from two different grids (one structured and one hybrid) but when, after some adaptions, both sets of results are stable I noticed they're significantly different. Every time I obtain results that are stable but specific for that particular mesh. Did you try to obtain same results with different grids?
Old   November 11, 2003, 10:02
levo
Thaks Mateus. I've tryied C structured and hybrid with O structured bounday layer but the results are always different. Moreover I think the non conformal adaption performed by Fluent could couse some mistakes inthe flux balance. A the time I've no idea of how get rid of grid dependency at all.
Old   November 11, 2003, 17:34
ap
You say:
"...when, after some adaptions, both sets of results are stable I noticed they're significantly different."
Does this means that if you refine the grid, results doesn't change but still are different on different grids?
If so, I'd think to some numerical problem of implementation on a particular kind of grid.
Hi
ap
Old   November 11, 2003, 22:36
dan
I thought Fluent's Grid Adaption only worked with unstructured meshes. I usually do grid refinement by going back to the mesh generator (GAMBIT) and doubling all the mesh parameters (i.e. number of nodes on an edge)
The only problem with this method though is that I have to make a new case file and re-input all the boundary conditions/etc
Dan
Old   November 12, 2003, 04:05
levo
Yes ap, this is what's happeneing: different stable results for every kind of grid. My be my grid generation method is wrong; is there anybody can show me the grid he uses for an airfoil? I'm not using wall functions, so I'd need y+<1. Thanks
Old   November 12, 2003, 10:31
ap
You're right: maybe there is a problem during the grid generation.
Unfortunately, airfoils don't belong to my field, so I can't be of great help.
Anyway, I think a grid like the one shown here (from NAG) should work:
http://www.nag.co.uk/simulation/Fast...ml/node141.htm
Just refine it to have y+ close to 1, using y+ adaption in FLUENT.
Hi
ap
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
grid dependency sri31049 ANSYS 3 March 3, 2010 07:12
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
