-   -   Problem about DPM (how to define injections) (http://www.cfd-online.com/Forums/fluent/32537-problem-about-dpm-how-define-injections.html)
lingo November 18, 2003 00:20
Hello,every one!
I'm simulating an atomizer with DPM.I don't know how to set the injection properties,such as "injector inner Diam','injector outer Diam','spray half angle','relative velocity','Azimuthal angle' and so on.Can I set several injections?I hope someone can give some advice.Thanks a lot!
lingo
Chendhil November 18, 2003 22:39
Re: Problem about DPM (how to define injections)
Hi
If you know your droplet size distribution in advance, you should consider using FLUENT's non-atomizer type models such as single, group, cone, etc.
If you are interested in the droplet size distribution itself, you may consider using atomizer type models (air-blast, pressure-swirl etc.). To start with, use FLUENT's default values. However, if you like to get a specific distribution, you will need to alter the injection parameters and/or atomizing air (if used).
Chendhil.
lingo November 19, 2003 00:30
Chendhil:
Thank you for your answer!
lingo
