-   -   rotating wall (http://www.cfd-online.com/Forums/fluent/32540-rotating-wall.html)
eric November 18, 2003 05:06
rotating wall
I have a rotating drum (2rpm) with fins on the wall. The flow is steady but I think the fact the wall rotates with fins makes the simulation unsteady.
I want to simulated this internal flow. However i want to avoid the unsteady simulation. Can i set the wall as a periodic boundary?
Or can I use the multiple refernece frame?
Any suggestions????
Eric
hbapply November 19, 2003 05:01
Re: rotating wall
If you just want to avoid the unsteady simulation, of course you can use the multiple refernece frame. But I can't undertand why you want to set the wall as periodic boundary.
ccc November 27, 2003 03:30
Re: rotating wall
hi eric,
I think, the multiple refernece frame plus sliding interface will work. However, why not try to solve your problem in the rotating reference frame.
good luck.
