CAVITATION "no CONVERGENCE in non-cavitating flow"
Old   November 19, 2003, 02:01
Default CAVITATION "no CONVERGENCE in non-cavitating flow"
ROOZBEH
Hi;
I want to model cavitation. I recently work with Fluent6.1.22. At the beginning of solution I work with a non-vavitating condition(high outlet pressure 50bar with my operating velocity 13m/s). If I turn on only the flow equations, the solutions converges; But at the same non-cavitating condition, if I add cavitation equation to the other equation,I do not have convergency(turbulence eq. converges but continuity do not converges) I did not have at least this problem with fluent6.0.12 !!!!!!! What settings are required for cavitating flow in this new version?
Thanks.
Old   November 19, 2003, 03:21
Default Re: CAVITATION "no CONVERGENCE in non-cavitating f
silver
hi cav3d software can help you . I have no experience with Fluent . It may be able to help you . but resemlit of this actbitec help the convegency of other acctual cases may occur in nature or even in non-cavitating condition .
Dr. silverpole
Old   November 20, 2003, 03:09
mateus
Hi!
On pressure outlet you have gauge pressure set to 50 bar? what's your operating pressure - 1 bar? As you know the sistem pressure is operating pressure + gauge pressure. It's good (in terms of convergence) to set operating pressure to a value about 1/2 of sistem pressure...I would set the operating pressure to 25 bar and gauge pressure on outlet to 25 bar...
Hope that this will help you...
Regards
MATEUS
Old   November 20, 2003, 03:14
mateus
Hi again!
As mentioned in documentation (22.5.3) you can also change the amg solver setings... You find this at Solve-controls-multigrid...
regards
MATEUS
Old   November 22, 2003, 02:19
ROOZBEH
Hi;
Thank you very much dear mateus! I will test with your suggestions. Oh, what did you mean about "sistem pressure"? Is it "absolut pressure" ?
Old   November 22, 2003, 02:59
ROOZBEH
Hi; Can I ask you what pressure discretization schem should I use(I use PRESTO!) ? What pressure-velocity schem(I use SIMPLE)? I use under relaxation factor .2 for pressure,continuity,momentum,vaporization mass, vof and .5 for turbulence. When I run my case with a high pressure outlet, approximatly whole of domain have pressure with a value equal to max value! and a not good convergence of continuity equation.
Old   November 22, 2003, 03:03
ROOZBEH
Hi again; Please excuse me. Where I should locate the reference point of operating pressure. I put it near leading edge of hydrofoil(CLE). Thanks
Old   November 26, 2003, 13:41
silver
hi could you check the software I suggest ?
bye
Dr.silverpole
Old   November 28, 2003, 04:00
mateus
Hi Roozbeh!
The presto scheme and simple algorithm look fine to me. The residuals look also in order. The thing I woul recomend is to move your reference point for operating pressure away from the hydrofoil - in the region where the flow conditions are constant...
Are you working on steady or unsteady simulation now?
Good luck
MATEUS
Old   December 1, 2003, 02:51
ROOZBEH
Dear;
This software is not available for me. I will be happy to work with cav3d software for an experience.
Regards
Roozbeh Mousavi
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Cavitation convergence problem Figd84 FLUENT 2 September 30, 2009 14:46
convergence problem with FLUENT cavitation model Belete Kiflie FLUENT 3 February 20, 2006 10:16
Kármán vortex street in cavitating flow behind bodies in the cavitation tunnel L. Könözsy Main CFD Forum 0 April 17, 2000 13:16
