reversed flow
Old   November 25, 2003, 10:48
Default reversed flow
amir
hi i recieved this message when fluent is trying to solve the problem " reversed flow ..... faces" do you know what's the problem?
Old   November 25, 2003, 16:02
Default Re: reversed flow
Paul
Hi
I face the same problem. I am solving flow and energy equations for a air in hemi clyinder and fixing temperature profile on one wall. my outlet is outflow bounday condition. I get the warning 'reversed flow at face 2 at outflow'. I am still trying to figure out the reason for this problem.
Amir, is your flow conditions similar to mine? Any help appreciated.
Old   November 26, 2003, 02:37
Jeff
I don't know exactly where the problem come from, but it's sure you have a convergence problem. Check you made enough iterations and check your residuals. Another source of problem can be the your outlet is too near from your cylinder (in the case of Paul). The distance between your outlet and the cylinder should be at least 15 diameters. And try using a pressure outlet boundary condition.
Regards.
Jeff
Old   November 26, 2003, 02:52
Louwrens
You're probably using pressure-outlet boundaries. On these you have to specify the backflow conditions for total pressure, temperature, turbulence etc, depending on the model. What you're getting is a message from fluent telling you that you don't just have outflow over your boundary but some inflow as well. Because the inflow conditions are calculated from the data you supplied, it might not be as accurate as when interpolated from the flowfield. Remember, it's never good practice to have reversed flow on the outflow boundary of your domain, rather move your boundary downstream...
Old   November 26, 2003, 06:46
mateus
Hi!
You can also make cells at outlet boundary very long and thin. This trick has a kind of damping function ang helps you get rid of reverse flow problem...
Hope it helps
MATEUS
Old   November 27, 2003, 06:25
Trilok
what boundary condition u r using at the outlet??
Old   November 27, 2003, 12:10
Paul
The boundary condition at the outlet is outflow. As jeff mentioned, i do face convergence problems whenever i get the reversed flow warnings.
Old   November 28, 2003, 03:45
mateus
HI!
Try it with pressure outlet. It's usually better for convergence.
regards
MATEUS
Old   November 30, 2003, 09:21
amir
Hi My boundary conditions are the same as Paul.(out flow) thank yuo.
reversed flow free FLUENT 4 February 27, 2014 01:56
reversed flow during RNG in turbulence-k epsilon Suman Kandula FLUENT 4 April 2, 2012 07:12
Reversed flow...>>>Please HELP...! sushii FLUENT 14 October 29, 2007 04:27
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
reversed flow Sastry FLUENT 5 March 22, 2007 08:05
