Home > Forums > FLUENT
modify prePDF database - combustion
Old   November 26, 2003, 13:21
Default modify prePDF database - combustion
David
hi,
thank you for the time and effort spent to solve my problem. I am trying to include a new specie to the prePDF database. In Fluent documentation, they say i can add new species to the database file, THERMO.DB and thermodb.scm. THe format for THERMO.DB is explained but how to calculate the polynomial coefficients? I have no idea of how to use the constrained linear least square fitting procedure.
Moreover, the FLuent documentations gives no description or literature to refer to in order to add the new species in thermodb.scm and how to get the coefficients.
If anyone can help and build up a suitable answer, i would be very grateful.
Regards
David
Old   November 27, 2003, 05:58
Default Problem solved:modify prePDF database - combustion
David
hi,
it seems that THERMO.DB file in linux is case sensitive that is why it was not taken into consideration.
So now it works
David
Thread Tools
Trackbacks are On
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 04:10
how to set periodic boundary conditions Ganesh FLUENT 13 January 22, 2014 05:11
prePDF preprocessor in FLUENT (ANSYS 12 version) anee Fluent UDF and Scheme Programming 7 March 18, 2013 23:57
incomplete prePDF database how to add new species munaf FLUENT 0 August 22, 2006 16:50
