Home > Forums > FLUENT
How to get the value of points by TECPLOT??
Old   November 28, 2003, 00:06
Default How to get the value of points by TECPLOT??
I am using TECPLOT to post-operate the FLUENT result, and want to get wall shear stress of special points. I had writen a MACRO to operate my work, but the result, the coordinate of points, are different to the value in the macro file. What is the reason? How to do correctly?
This is my macro file: #!MC 900
$!READDATASET '"-LoadOption" "GridAndSolution" "-CaseFile" "E:\unsteady.cas" "-GridZones" "BoundariesOnly" "-DataFile" "E:\unsteady.dat"'
DATASETREADER = 'Fluent Data Loader'
FNAME = 'E:\Jwt\FlowChamber\Bifurcation\WSS_P_C&N\WSS-P-C&N_|F1|.dat'
3.69074582597831E-03 5.2885748683387E-03 0
6.13156673884702E-03 6.65591994596276E-03 0
8.71635654747554E-03 7.86122722844724E-03 0
1.13471443689967E-02 8.82118695579832E-03 0
1.42134653175816E-02 9.56945325846278E-03 0
1.70509637007159E-02 1.03795297522031E-02 0
The result as follow: VARIABLES = "X" "Y" "Z" "Pressure" "X Velocity" "Y Velocity" "Z Velocity" "Mass Flux" "Mass Flux M1" "Variable #114-1" "Variable #114-2" "Variable #114-3" "Wall shear-1" "Wall shear-2" "Wall shear-3" "Boundary heat flux" "Boundary rad heat flux" "Density" "Density t-1" ZONE
0.0132126529555 0.00875424914337 0.00170419006373 .......(omited)
0.00828271565594 0.0072761538821 0.00153740363191 .......(omited)
0.00128266168341 0.00393154471282 0.00108209568066 .......(omited)
-0.00341266672621 0.00295671212011 0.000888105272212 .......(omited)
-0.00742063295438 0.00300233585155 0.000766922960434 .......(omited)
-0.0114099025797 0.00302589492282 0.000656996585406 .......(omited)
Old   January 21, 2011, 19:01
Default same issue here
Vian is on a distinguished road
I am facing the exact same problem: how to use the "probe" tool to extract data from a point through a macro, without having to manually click on the point.
It seems that the coordinates that need to be input in the macro after RAWDATA have to be in some odd 2D coordinate system. I couldn't find any information on how to switch from that system to the physical coordinates.
Any help welcome!
Vian is offline   Reply With Quote
Old   January 21, 2011, 20:53
Default Tecplot data probe using python
Scott Rumage
scott_rumage is on a distinguished road
If you are using Tecplot 360 2008 R2 or later, you will find a python example script called and located on your computer at ...tecplot\tec360 \examples\python
Perhaps you would be able to edit this script to probe your data via batch mode (or script).
scott_rumage is offline   Reply With Quote
Old   January 21, 2011, 21:12
Scott, thanks for your quick answer.
I didn't want to look into Python scripting (was using Tecplot's funky macro language) but I guess I'll have to ; the example seems indeed to be promising!
Old   March 31, 2015, 06:18
Default python script works but encountered some problem
aeroiitkgp is on a distinguished road
Thank you scott_rumage for the info.
I tried to use this script to extract values in a given 3D dataset. It works well except for some points when its giving the error " no such point in dataset".
If I try to enter the same point through the probe at tool in gui, I observe that tec360 approximates that point to the nearest available point and gives a result, but the python script is not able to do that.
How do I modify the script to allow it to find nearest possible point in data?
aeroiitkgp is offline   Reply With Quote
Thread Tools
Trackbacks are On
Sliding Interface issues philippose OpenFOAM Running, Solving & CFD 7 May 5, 2014 03:13
jagged, ragged edges... ziemowitzima OpenFOAM Native Meshers: snappyHexMesh and Others 138 July 23, 2012 23:41
Gauss Quadrature points dhruv OpenFOAM 4 September 26, 2011 04:59
BlockMeshmergePatchPairs hjasak OpenFOAM Native Meshers: blockMesh 11 August 15, 2008 07:36
extreme points problem Lipo Wang Main CFD Forum 2 August 18, 2004 03:15
