-   -   HEAT TRANSFER AND EULER-EULER model (URGENT pls) (http://www.cfd-online.com/Forums/fluent/32630-heat-transfer-euler-euler-model-urgent-pls.html)
thomas December 1, 2003 10:32
I need to solve the energy equation using the Euler-euler model. What I am doing is simulating the heat transfer from a constant heat flux through a wall using an inpingging jet.
Is someone has already done that or can just tell me if there is a UDF for that. Any documentation will also be welcomed.
thomas
krishna December 17, 2003 02:31
Re: HEAT TRANSFER AND EULER-EULER model (URGENT pl
Dear Thomas,
First of all I am not fully aware of ur problem, but i am sure that u can simulate energy transfer using Euler-Euler model using Fluent version 6.1 only. If ur using Fluent 6.0 version, it is not possible using in built equations..may be u can write an UDF for that..
krishna
thomas December 17, 2003 05:01
Thanks for your answer, I am using fluent 6.0 so I already begin to build a UDF to transport the temperature in the domain. Thanks again.
