-   FLUENT (
-   -   transient solid condution (
Bikash December 3, 2003 19:38
Hi, im using Fluent6. i want to input the source term which is varying with time. just the source term, the boundary conditions are not changing. i have the datas of how the source term is changing with time. how do i input the source term?
it would be a great help if anyone would lead me the way.
regards bikash
Andrew Garrard December 4, 2003 05:54
Re: transient solid condution
I believe the only way that you can achieve this is with a UDF. If that is the case and you have not created a UDF before then you are faced with a decision of either finding someone who will make one for you, possiable for a fee, or learning UDF programming and doing it yourself.
Check out the UDF manual for Fluent 6.
bikash December 4, 2003 11:20
hi andrew
thanks a lot for ur advice. let me try the UDF, hope i can do something.
thank you bikash
co2 December 4, 2003 23:16
take a look at the following udf for varying temperature at a boundary. your udf will look similar but it will act on the source term.
/************************************************** ********************/ /* unsteady.c */ /* UDF for specifying a transient velocity profile boundary condition */ /************************************************** ********************/
#include "udf.h"
DEFINE_PROFILE(unsteady_temp, thread, position) { face_t f;
begin_f_loop(f, thread)
real t = RP_Get_Real("flow-time");
F_PROFILE(f, thread, position) = 350. + 5.0*t;
} end_f_loop(f, thread) }
bikash December 5, 2003 11:33
hi thanks a lot for ur help.
regards bikash
