December 8, 2003, 11:34 |
tripping over udf's
hi guys. here is a simple question with, very possibly, a simple solution but i can't get my head around it. i'm trying to use udf functions in fluent 6.1, but the solver comes up with an error message stating that it is unable to open udfconfig.h for write. I suppose this must be the header file needed to read the udf's. Anybody knows whether i need further configuration of the software or if i am missing an important step? Thanks
December 8, 2003, 11:38 |
Re: tripping over udf's
Try having your case and UDF under c:\Fluent.inc\ntbin\ntx86 directory. This might help.
-Ajay |
December 8, 2003, 12:02 |
hi. Thanks for the quick reply. I tried, but i'm afraid it does not seem to work.
December 8, 2003, 13:08 |
try interpreting one of the simple UDF's from the tutorials. So that you could pin point the source of the error. If you get the same error then something must be wrong other than your code. All the best Ajay
Display Modes | |
problem using property udfs in parallel mode | EllenW | Fluent UDF and Scheme Programming | 5 | July 10, 2009 04:31 |
problem using property udfs in parallel mode | EllenW | FLUENT | 0 | June 23, 2009 17:18 |
Unsteady and Flux UDFs for UDSs | tom | FLUENT | 0 | February 13, 2009 10:27 |
How to use more than one UDFS in one problem | Thanh | FLUENT | 2 | August 13, 2008 21:28 |
Experimental Repository for UDFs, Journal Files and Scheme Scripts | Jonas Larsson | FLUENT | 0 | March 5, 2000 15:36 |
