December 8, 2003, 03:48 |
heat transfer betwen gas and particle
hi i have aerosol simulation with fluent. that aerosol flow in cyclone. I model it with discrete phase.In my model, i include energy radiation(P1) equation The gas(air) has temperature 823 K and particle is 323 K. Gas has mass = 43 kg/s and prticle is 35 kg/s. Particle(inert particle) has density 2800 kg/m3, Cp=1200 kj/kgK and emisivitas particle is 0.9. The wall of cyclone is adiabatik. When the simulation is finish and i check gas temperature. but gas temperature is still 823K.
Please if anyone know about that, tell me what i must do. thank you |
December 8, 2003, 04:56 |
Re: heat transfer betwen gas and particle
hi,
did you activate the energy equation? cheers David |
December 8, 2003, 06:24 |
Make sure you check the 'Interaction with continuous phase' box in the Discrete Phase menu.
December 8, 2003, 18:33 |
Hi David yes, i had activated the energy equation but the end of simulation gas temperature still like that. i am very confuse. thank for your suggest
December 8, 2003, 18:39 |
Hi Erwin Yes. i had include interaction partilce with continous phase. The option which i activated were particle radiation ineraction and coupled heat mass solution. thanks for your response.
December 8, 2003, 18:42 |
Hi Erwin Yes. i had include interaction partilce with continous phase. The option which i activated were particle radiation ineraction and coupled heat mass solution.But the gas out temperature is still like gas tenperature inlet. thanks for your response.
Problems involved heat transfer inside a particle and its thermal degradation | zhangr | STAR-CCM+ | 2 | August 25, 2011 06:59 |
