heat transfer betwen gas and particle
Old   December 8, 2003, 03:48
Default heat transfer betwen gas and particle
eri andika
hi i have aerosol simulation with fluent. that aerosol flow in cyclone. I model it with discrete phase.In my model, i include energy radiation(P1) equation The gas(air) has temperature 823 K and particle is 323 K. Gas has mass = 43 kg/s and prticle is 35 kg/s. Particle(inert particle) has density 2800 kg/m3, Cp=1200 kj/kgK and emisivitas particle is 0.9. The wall of cyclone is adiabatik. When the simulation is finish and i check gas temperature. but gas temperature is still 823K.
Please if anyone know about that, tell me what i must do.
thank you
Old   December 8, 2003, 04:56
Default Re: heat transfer betwen gas and particle
David
hi,
did you activate the energy equation?
cheers
David
Old   December 8, 2003, 06:24
Erwin
Make sure you check the 'Interaction with continuous phase' box in the Discrete Phase menu.
Old   December 8, 2003, 18:33
Eri Andika
Hi David yes, i had activated the energy equation but the end of simulation gas temperature still like that. i am very confuse. thank for your suggest
Old   December 8, 2003, 18:39
Eri Andika
Hi Erwin Yes. i had include interaction partilce with continous phase. The option which i activated were particle radiation ineraction and coupled heat mass solution. thanks for your response.
Old   December 8, 2003, 18:42
Eri Andika
Hi Erwin Yes. i had include interaction partilce with continous phase. The option which i activated were particle radiation ineraction and coupled heat mass solution.But the gas out temperature is still like gas tenperature inlet. thanks for your response.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Problems involved heat transfer inside a particle and its thermal degradation zhangr STAR-CCM+ 2 August 25, 2011 06:59
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
