September 19, 2012, 15:44 |
Unsteady case
m.reza
Rep Power: 14 |
Hi
I study on an unsteady case, my time step is equal to 0.0001 and I need to get average between Nusselt number of each time step in x direction. I have 1000 time steps in my analyzed at least. Is there a method in Fluent that I want to have a graph of time-averaged Nusselt Number distribution on the hot surface finally? |
September 19, 2012, 21:40 |
#2 | |
Syavash Asgari
Rep Power: 17 |
I'm a little confused with your case! What do you want to obtain exactly?! Time-Averaged mean Nusselt number of all time steps or mean Nusselt number at each time step?!! What is the physics of your problem?! You are studying on an external or internal flow?! |
September 20, 2012, 05:56 |
tnx syavash
m.reza
Rep Power: 14 |
Dear Siavash,
I study on a jet that targets to the hot surface for cooling, the profile of velocity in the jet inlet is sinusoidal, so my case is unsteady. My time step is 1e-4 and for example in the frequency of 10Hz, I have 1000 time steps only in one cycle, I have to run this case for 5 cycles. Finally I want to draw time-averaged Nusselt number on the hot surface. I have one method that I write data file of each time step and then export local Nusselt number of that time step. So I get average between nusselt numbers, and then draw time-averaged local Nusselt number. I look for a simply method in Fluent that it doesn't take much time. Can you help me? |
September 20, 2012, 11:03 |
Syavash Asgari
Rep Power: 17 |
I see. I think you would be able to do this by means of a UDF.
At first you have to calculate local Nusselt number based on surface heat flux and a reference Temperature. Then you should sum all the Nusselt number of all time steps for each computational face separately. At the end you should divide the ُsummation of Nusselt numbers obtained in previous step by the flow time. It can be done by utilizing a Define_Adjust and Define_Execute_on_demand Macro. Bests. |
July 6, 2018, 11:20 |
#5 | |
iran VS america
Rep Power: 8 |
Hello I need this code Can you give me please I don’t know how how to write it Please help me!!! |
Display Modes | |
udf parabolic velocity inlet with unsteady case | Faruk Beyca | FLUENT | 4 | June 24, 2022 11:45 |
MRFSimpleFoam wind turbine case diverges | ysh1227 | OpenFOAM Running, Solving & CFD | 2 | May 7, 2015 11:13 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
Unsteady Case | Q | FLUENT | 7 | January 14, 2006 00:11 |
Parallel Scaling in Unsteady Sliding Mesh Cases | Jonas Larsson | FLUENT | 9 | September 5, 2000 11:13 |
