Home > Forums > FLUENT
Changing turbulent viscosity
Old   December 16, 2003, 17:25
Default Changing turbulent viscosity
ap
I'm trying to change turbulent viscosity of the gas phase in the Eulerian model using UDF.
I'm using a DEFINE_ADJUST to do that, but I get an error message when I compile my code.
The compiler tells me:
(172) : error C2106: '=' : left operand must be l-value
where line 172 is
C_MU_T(cell, pt[GAS_PHASE_INDEX]) = my_visc;
The error doesn't happen if I try to read the turbulent viscosity value.
It seems like I can't change it's value.
Any advice is really appreciated.
Hi
ap
Thread Tools
Trackbacks are On
reversed flow at pressure inlet and turbulent viscosity is limited.... cfdiscool FLUENT 10 June 10, 2015 06:15
Turbulent viscosity and shear rate shib FLUENT 0 June 22, 2010 12:44
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
Problems with changing turbulent viscosity by UDF sarah_ron FLUENT 0 February 14, 2005 01:31
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
