pressure distribution in a closed container
Old   December 16, 2003, 23:13
Default pressure distribution in a closed container
prasanth
HAI,
1).In a closed cylindrical tank completely filled with liquid, if we give intial pressure distribution of static head using custom field functions, it was taking the profile while patched. When on heating on cylindrical surface(i.e., during iteration), pressure is going to normal operating conditions, i.e. in the range of atm. pressure...why is it so? is it not taking initial condition?
2) One more thing, In tha above case, a little positive gradient is achieved in pressure along height, which is acceptable. but when patch liq heiht only to 80% and remaing 20% with vapor,also same as above, but it is showing -ve gradient towards interface and going in +ve direction from there to the top? why its happening like that?
Advance thanks for any kind information.
Prasanth
Old   December 17, 2003, 11:01
Default Re: pressure distribution in a closed container
prasanth
I guess people have not understood my query. Let me say in another way:
1) take an axisymmetric model of a cylindrical tank. take that it is fully filled with liquid. now taking all the steps for natural convection, by applying constant heat flux on side-wall, etc.;create a custom field as rho*g*(height-coordinate in g dir)(i,.e., rho*g*h].patch this custom field as pressure on the fluid zone after initializing. then see the pressure profile along the axis. now after some iterations again see the pressure profile. I observed as it going in the range of operating pressure instead of taking the patched pressure distribution as initial stage.
So, can you sort out my problem. If any understand this, I will post my second question
Thanks in Advance Prasanth
Old   December 21, 2003, 06:52
Venkatesh
I feel you have not swithced on the gravity.
Old   December 21, 2003, 07:21
prasanth
without gravitation, we cant simulate natural convection. i have selectewd it. with regds prasanth
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 10:08
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 13:45
Pressure Rise Error emueller CFX 0 May 5, 2009 11:08
plot pressure distribution on a section of 3D wing ROOZBEH FLUENT 3 April 21, 2008 03:30
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
