December 17, 2003, 23:50 |
Please Help! (Fluent Error)
Hi.
Sometimes, when I run iterations in Fluent 6.0, I obtain this error statement: Error: > (greater-than):invalid argument [2]:wrong type [not a number] Error Object: nanOx7ffffe00 May i know what's the meaning of this error? How to resolve it?? Regards |
December 18, 2003, 04:20 |
Re: Please Help! (Fluent Error)
I have seen the same thing. Very mysterious. It seems to have something to do with the residuals, but I don't know what. The only way I have managed to resolve is to initialize again and restart the calculations.
December 18, 2003, 04:36 |
When you recieve an error with NAN or not a number, it usually means that one on of the variables has increased to beyond the limits of FLUENT. It could mean that you have a divergent system do to one of the constants you set. Have a look at the residuals and see if one of them shoots up at the time of your error.
December 18, 2003, 12:56 |
I have a question for you: did this error occur after you repartitioned an existing case file and tried to continue the iterations??
December 21, 2003, 06:48 |
Did you got any warning message before getting this error message ? You will get this error message when the flow variables reach unrealistic values (eg: pressure reaching zero or density reaching zero). One way to handle is that limit the flow variable values with in limits( you will be have a rough idea of what the values of pressure ??).
And start the analysis with low under relaxation values .. |
January 5, 2004, 04:02 |
Venkatesh is quit right
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
error while running paraFoam! | padmanathan | OpenFOAM | 9 | October 13, 2009 05:17 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
