a udf problem
Old   December 24, 2003, 20:47
Default a udf problem
zht77
hi,i have tried to compile the following code(using interpreted),but an error is appeared.the code is able to be complied ,however, when i execute execute on demand ,the error is appeared.if an real number (such as 2.55)replace C-VOLUME ,everything is ok,and there are n 2.55 being appeared( n is the number of the cell in the domain 1.)
But i compile the code (using complie),everything is ok,however, nothing is appeared in terminal emulator.even if an real number (such as 2.55)replace C-VOLUME ,anything does not alter.
thank you very much. DEFINE_ON_DEMAND(on_demand_calc) { Domain *d; real nn = 0.; Thread *t; cell_t c; d = Get_Domain(1); /* Loop over all cell threads in the domain */ thread_loop_c(t,d) { begin_c_loop(c,t)
nn=C_VOLUME(c,t);
printf(" %g ",nn );
} end_c_loop(c,t)
} } Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: ()
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
UDF problem mansha goraya FLUENT 0 October 29, 2007 00:31
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
UDF problem chiseung FLUENT 4 January 10, 2002 09:58
