Home > Forums > FLUENT
compiling a UDF
Old   December 26, 2003, 20:55
Default compiling a UDF
co2
I am trying to follow the steps in the UDF manual at
7.3.3 Compiling and Building Your Shared Library
to compile a particular UDF.
When I give the nmake command at the command prompt, I am getting the following error --
R:\1\libreactor\ntx86\2d>nmake clean
Microsoft (R) Program Maintenance Utility Version 6.00.8168.0 Copyright (C) Microsoft Corp 1988-1998. All rights reserved.
Could Not Find R:\1\libreactor\ntx86\2d\*.dll
Can someone tell me what is going on ? What am I doing wrong ?
Old   December 29, 2003, 07:36
Default Re: compiling a UDF
emma
If you compile udf in windows, you'd better install one c /c++ compiler, e.g. visual c++ 6.0, and make sure that all the necessary dynamic library files are installed. Hope it helps somehow.
Emma
Old   January 5, 2004, 20:34
Rob Hart
Can't say I've done this under windows, but....
"nmake clean" is probably designed to clean up the files created by compiling the UDF. I imagine it is trying to delete all the .dlls, but in this case you don't have any.
I am not familar with microsoft make, but under unix you can do something like:
make -k clean
which ignores errors.
Alternatively open up the Makefile in a text editor, and see what it is doing.
Thread Tools
Trackbacks are On
About UDF compiling issues: 'nmake' Haoyin Shan Fluent UDF and Scheme Programming 7 January 2, 2013 11:49
Compiling UDF on a cluster Adya FLUENT 1 December 14, 2009 12:30
UDF compiling problem in Flient 6.3 jeevan kumar FLUENT 2 February 25, 2009 01:43
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
On Compiling a UDF David Chabot FLUENT 5 May 20, 2005 09:13
