December 26, 2003, 05:39 |
nusselt number procedure in fluent
I'm working on effect of distance on Natural convection between horizontal plates that are open ended and heated from below. My discussion is how fluent calculates the nusselt number and its correlation? which equations it is using? and how it calculates the heat transfer coefficient(h)? I'll be looking for your help. you can e-mail me
December 26, 2003, 17:59 |
Re: nusselt number procedure in fluent
Fluent uses for heat transfer:
h = q''/(T-Tref) Tref : user specified; q'' and T: fluent calculated More information, you can get from documentation. |
December 29, 2003, 06:04 |
thx ashu! that helped me.bye
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
How to get the Global Node Number by UDF : Fluent | Yusuke | FLUENT | 1 | October 23, 2015 10:55 |
Problem with decomposePar tool | vinz | OpenFOAM Pre-Processing | 18 | January 26, 2011 02:17 |
Local Nusselt Number | rohangulavani | FLUENT | 0 | July 6, 2010 07:03 |
Fluent 6.4 courant number | Aris Nikolopoulos | FLUENT | 0 | May 6, 2008 08:52 |
