2D-udf
Old   January 4, 2004, 07:15
Default 2D-udf
vimal
I am using a 2D udf for velocity at Inlet. aftre compiling it using
the message coming is
cpp: output pipe has been closed
and it is not showing udf in the velcity_inlet panel. Plz suggest me is this an error
Old   January 5, 2004, 19:40
Default Re: 2D-udf
Rob Hart
Have you successfully compiled other UDFs before?
The most likely cause is that there is an error in your source code. I have found the supplied cpp being quite useless when it comes to providing meaningful error messages (even compared to other c compilers)
Maybe you could post your UDF file? These things are normally blindingly obvious to people who haven't spent hours staring at the file already ;-)
Rob
Old   January 5, 2004, 22:40
Default Re: 2D-udf
vimal
Thnks Rob,
There was some problem with the file uploading from PC to unix system, so the file has got damaged during uploading. I got the solution.
Vimal
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
