-   -   constant Heat flux at the wall (http://www.cfd-online.com/Forums/fluent/32824-constant-heat-flux-wall.html)
hatta January 9, 2004 01:27
I have a 3D geometry, for which i have to calculate Nusselt number using constant Heat flux at the wall throughout the length of the tube. Can i use the FLUENT funcion
Boundary conditions --- wall ----- heat flux or i have to write some UDF for this.
Andrew Garrard January 9, 2004 05:45
Re: constant Heat flux at the wall
If you wish to simulate a heat flux that is constant with time, and position on the wall, then you can use default FLUENT function. UDF's are used to create variable, functionally dependant boundary conditions.
hatta January 9, 2004 08:13
Thanks Andrew
