Home > Forums > FLUENT
Please help: How to set BC for the mass diffusion
Old   January 12, 2004, 00:14
Default Please help: How to set BC for the mass diffusion
Pete
HI,
I'm trying to solve a simple mass diffusion problem. Two reservoirs separated by a thin membrane. One reservoir fills with NaOH, the other just distrilled water. And I want to measure the concentration of OH at the other reservor for a certain time. I just want to do it in 2D ( and only x-dir flow). So the configuration would be very simple, a rectangular (is this correct? or does it need to be 3 rectangulars i.e. left reservoir, membrane (solid), and right reservoir???).
Question?
1. What type of the Boundary condition for left and right side of the membrane? 2. I believe I need to input the mass flow rate (or mass flux), but since the OH is in the reservoir and just diffuses by the concentration gradient, velocity should be zero, shouldn't it? 3. is there any example of diffusion problem in Fluent help?
Thank you very much for your help in advance. Pete
Old   January 13, 2004, 04:27
Default Re: Please help: How to set BC for the mass diffus
tyw
for you first question, I think u can try the porous jump bc to act as the membrane. havent use it, but the fluent manual describe it can be use as a performable plate. I suppose it also can be use to act as a thin membrane??
2q, are you try to simulate the diffusion of the NAOH or just the OH ion itself?? in the case of diffusion of the ion, i think you need to create the two ions, i.e. NA and OH. then you must know the diffusivity of both ion. If I remember correctly we need to input the D by ourself.
hope this help tyw
Old   January 13, 2004, 10:47
Pete
Thanks for your suggestion tyw,
I'm looking for only OH ion, not Na ion.
What about the mass flow rate? The diffusion occurs because of the concentration gradient, no flow? ( Can I assume to be a laminar flow with very low velocity?)
Thanks, Pete
Old   January 15, 2004, 21:23
tyw
are you simulating a closed system, if closed system then i dont think we need to input the mass flow rate. even if you want to give the mass flow, where do you think the mass flow b.c. are?? Since you are tring to simulate a concentration gradient driven diffusion, i dont think we need to difine the mass flow. Just provide the gradient and diffusion should be triggered
for diffusion of different ions, i think you need to create three different species: NA,OH and the third species in the other chamber.
May be you can try a more simple setting first??: just two connected chamber with out the present of the membrane??
I suggest you refer to the species transport tutorial provided in FLUENT. inside the tutorial you can learn how to setup a diffusion simulation.
hope this help.
tyw
Old   August 7, 2013, 00:53
chia chun
kayne91 is on a distinguished road
hi there,
i am also trying to simulate a pure ion diffusion process across a membrane (without any flow). is species transport the right model to start with?
Regards,
kayne
kayne91 is offline   Reply With Quote
Old   August 8, 2013, 11:47
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
Hi
Yeah, you can do it by species transport or even you can define a UDS. The only thing you need to care about is the right model for diffusivity or already have it experimentally.
Regard yours
A CFD free user is offline   Reply With Quote
Old   August 8, 2013, 20:58
chia chun
Originally Posted by A CFD free user View Post
Hi
alright. thank you so much for your advice. now i am confident to continue with my model research.
Thread Tools
Trackbacks are On
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Solve a mass diffusion problem Roberta FLUENT 0 November 26, 2008 02:47
mass diffusion vs temperature UDF alex FLUENT 0 March 5, 2008 12:38
mass diffusion help Jill FLUENT 0 July 6, 2004 21:35
How to set mass fraction at inlet boundary conditi Eric CFX 3 September 8, 2003 13:09
