-   -   setting diffusivity in different domains (http://www.cfd-online.com/Forums/fluent/32844-setting-diffusivity-different-domains.html)
Andrew Garrard January 14, 2004 08:56
I am trying to set the diffusivity in a part of a flow domain. How do I identify on of the flows given the Boundary ID for example. say I have two volumes, flow1 and flow2, that are conncect and I wish to set the diffusivity diffently in each flow diffenetly. I can read the boundray ID for flow1 and flow2 from the fluent boundry panel and the thread pointer is passed in the udf. I am struggling to work out how to compare these. The psudo udf would look like this:
DEFINE_DIFFUSIVITY(name, c, t, i)
if (thread is in flow1) {return (value1);} if (thread is in flow2) {return (value2);)
DAE January 14, 2004 10:35
Re: setting diffusivity in different domains
My understanding is that diffusivity is a material property. Why would you want to set a different value in different parts of the domain?
DAE
Andrew Garrard January 14, 2004 11:23
Thanks, but that dosent answer my question. To answer yours, material properties can vary. For example, vicosity changes with temperature. My material property could change when, say, entering a magnetic or electrical field.
DAE January 14, 2004 11:42
Does this help?
/****************************************/ /* UDF that computes diffusivity */ /****************************************/
#include "udf.h"
DEFINE_DIFFUSIVITY(diffusivity, c, ct, i) {
Domain *domain = Get_Domain(1);
Thread *ct1 = Lookup_Thread(domain,90);
/* Declare ct1 as a pointer to a cell thread */
Thread *ct2 = Lookup_Thread(domain,91);
/* Declare ct2 as a pointer to a cell thread */
begin_c_loop(c,ct1)
return *****************
end_c_loop(c,ct1)
begin_c_loop(c,ct2)
end_c_loop(c,ct2)
Volker Pawlik January 14, 2004 11:45
you want to identify the zones locally (which is flow1 and which is 2?) is it that what causes your problem?
If yes, the easiest way is to create a surface zone of your fluid-zone, i.e. the boundary of the zone will form a new surface-zone which can be displayed by the display-grid panel.
Creating a zone is done by the /Surface/Zone menu.
Volker
Andrew Garrard January 17, 2004 10:12
Thankyou for your comments. DAE: Your solution to the problem is a nice one, however, the problem is that in the UDF manual, it says:
"Note that diffusivity UDFs are called by FLUENT from within a loop on cell threads. Consequently, your UDF will not need to loop over cells in a thread since FLUENT is doing it outside of the function call."
So I believe that I cannot runn a cell loop in the UDF.
Volker: I really need to identify my fluid zones within a UDF.
