Home > Forums > FLUENT
Warning for multiphase flow
Old   January 14, 2004, 18:28
Default Warning for multiphase flow
I am simulating the multiphase flow with Fluent.
After Fluent read the grid, I received the following message:
Warning: materials in neighbor cell threads (2 and 1) of interior zone 5 are of different types (new_material and aluminum).This problem MUST be fixed before solving!
How do I fix this problem?
Many thanks,
Old   January 15, 2004, 14:39
Default Re: Warning for multiphase flow
Does this happens when you read the msh file, or when you open a case file after calculation?
How do you define materials?
Old   January 16, 2004, 20:39
************************************************* sure you have two different types of basic material
fluid and solid....this can only be done by setting a wall(gambit) and set it to "coupled" in Boundary panel (Fluent)...all convectional parameters f.e heat transfer coeff is automatically solved by fluent f(Re,Pr).
greetz optixxx
Thread Tools
Trackbacks are On
installing funkySetFields prapanj OpenFOAM Installation 65 October 8, 2015 17:46
wmake groovyBC in OpenFOAM 1.7 ? randomid OpenFOAM Running, Solving & CFD 1 August 27, 2010 05:15
Cells with t below lower limit Purushothama CD-adapco 2 May 31, 2010 21:58
Need help with the error cfdproject OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 0 April 14, 2009 15:45
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
