Temperature Functions for walls
I want to set for a wall a time-dependent temperature 1. 0-10 min temp is increasing linear from 300 to 400k 2. after 10 min to 60min temp is constant 400k Sure that must be done with unsteady time steps lets say a time step has 0.5 sec Sorry,i´m learning UDF atm and not familiar with it atm. with my small programming knowledge if t<= 1200 T=T+0,0833333 else T=400 end if 10min=1200 timesteps and 0,08333= 100/1200 can someone help me..setting a profile or UDF for it? would be happy about any help Optixxx |
Re: Temperature Functions for walls
You don't need time step. And time scale is "second".
Please use the file as below; cut and paste, and name as "it.c", and read Define/User-Defined/Functions/Interpreted and write in "Source File Name" as "it.c" and Define/Boundary Conditions/ If you are Fluent User, after explanation will not be necessary. /* -------increasing temperature file--------- */ #include "udf.h" /* temperatu define */ DEFINE_PROFILE(temperature_profile,thread,position ) { face_t f; begin_f_loop(f,thread) { real t = RP_Get_Real("flow-time"); if ( t < 600.0 ) F_PROFILE(f,thread,position) = 300.0+0.16666667 * t; else if ( t < 3600.0 ) F_PROFILE(f,thread,position) = 400.0; else F_PROFILE(f,thread,position) = 400.0; } end_f_loop(f,thread) } |
Wonderbra It works without any errors...many Thx TAMO2 Tested it on the surface intergal result-panel Greetz Optixxx |
