January 23, 2004, 11:57 |
Thermal B.C at walls
Hi everyone,
There is 5 options in thermal B.C at walls, do I have to choose only one of them or can I choose more than one if I know all the parameters? In case I choose only one, say heat flux, does fluent take into consideration the default value, for the specified temperature for example, in the calculation? Thank you so much. |
January 26, 2004, 05:07 |
Re: Thermal B.C at walls
When setting a thermal boundary conditions you can only specify heat flux OR temperature. To set both would be to overconstrain the equations. If you set the heat flux the code should calculate the temperature and visa versa. For example, if you set the heat flux and the local velocity increases then the temperature at the wall may well drop due to increased convection.
Hope some of this helps |
January 26, 2004, 19:52 |
or you could specify a heat transfer coefficient and an external temperature, in which case Fluent will calculate a wall temperature and a heat flux based on those boundary conditions.
January 27, 2004, 13:57 |
Thank you so much Andrew and Anton.
Thermal Conditions for Two-Sided Walls | Tomm | FLUENT | 3 | December 8, 2005 02:03 |
thermal conditions of walls | Stefan | FLUENT | 2 | March 23, 2003 06:17 |
about thermal conditions for two-sided walls | Devy | FLUENT | 8 | September 26, 2001 12:42 |
Short Course: Computational Thermal Analysis | Dean S. Schrage | Main CFD Forum | 11 | September 27, 2000 17:46 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
