January 28, 2004, 06:01 |
CAVITATION_low Re effects
Hi;
Should I set the option "differential viscosity model" in RNG k-e model for a cavitating flow Thanks ROOZBEH |
January 29, 2004, 01:13 |
Re: CAVITATION_low Re effects
Generally speaking, you enable it if your mesh is designed for integrating the governing equations down to the wall. In contrast, if it is too coarse close to the boundary, you should use a wall function approach. In latter case, the differential viscosity model should be disabled. Check e.g. the y+ values to get a guess what kind of near-wall treatment you need.
I don't know for which combination (cavitation model + fine near wall grid + low-Re model or cavitation model + coarse near wall grid + "standard" turbulence model) you will get improved accuracy as I have not been using it very much. However, I could imagine that a setup with fine grid + low-Re model is better suited since bubble creation and growth appears in general close to the boundary. Accordingly, a "standardised" formulation might not be the proper choice for modelling strong diparities. Philipp Beierer |
Enhanced Wall Treatment - Thermal Effects | Brian Tang | FLUENT | 1 | November 5, 2015 23:59 |
Solar Load Effects in Fluent | Boreas | FLUENT | 1 | December 15, 2010 00:15 |
Group effects & fluid structures | diaw | Main CFD Forum | 1 | October 27, 2006 06:04 |
Buoyancy effects with species transport models | Brian Tang | FLUENT | 0 | December 1, 2005 05:25 |
PDF with Compressibilty Effects | Tang | FLUENT | 0 | November 19, 2004 13:17 |
