DEFINE_DPM_OUTPUT udf
Old   January 28, 2004, 17:40
Default DEFINE_DPM_OUTPUT udf
K. Kevala
I am trying to write a DEFINE_DPM_OUTPUT udf so that I can track particles as they move through my domain and also assign a strain rate to each particle at each location in the domain. (time dependant - moving mesh).
As a first step, I am writing a simple template just to see if I have the idea. I have written the following:
#include "udf.h"
DEFINE_DPM_OUTPUT(history,header,fp,p,t,plane) {
fp = fopen("myfile.txt","a+");
if(header)
fprintf(fp,"This is a test\n"); else{
if(p==NULL)
else{
fprintf(fp,"%10.6f",P_VEL(p)[0]);
fprintf(fp," %10.6f",P_POS(p)[0]);
When I interpret the UDF, I get the error message:
Error: D:\velocity_history.c: line 18: P_POS: undeclared variable
However, if I remove the last fprintf statement (containing the P_POS(p)[i] macro which is clearly defined in the manual as giving particle position for i=0,1,2 (and also in dpm.h), then there is no problem. Is the P_VEL(p) macro correct, but I am using P_POS(p) incorrectly? With just the P_POS(p) statement in my udf, Fluent interprets the udf ok and gives an output file that seems reasonable after I hook it into the report->dpm->summary gui. Thanks for any suggestions.
Karl
Old   January 29, 2004, 08:38
Default Re: DEFINE_DPM_OUTPUT udf
Robert Hart
I just had a look in dpm.h, and somewhat oddly, you have
#define P_VEL(p)(p->state.V)
and
#define P_POS(p,i)(p->state.pos[i])
This seems to imply that you should use P_POS(p, 0) in your function above, but P_VEL(p)[0].
Go figure
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
