Home > Forums > FLUENT
How to run Fluent on the background?[continued]
Old   January 30, 2004, 08:54
Default How to run Fluent on the background?[continued]
David
In the CVF6.5 platform, these sentences can start fluent:
USE DFLIB LOGICAL(4) result result = SYSTEMQQ('fluent.bat') end
and 'fluent.bat' is:
@echo off (cd %systemdrive%\TEMP & %FLUENT_INC%\ntbin\nt%PROCESSOR_ARCHITECTURE%\flue nt 3d(or 2d) %*)
then doing the operation "read->journal" in the started Fluent window can partly realize the automatically running Fluent.But whether this action "read->journal" could complete in the outer Fluent window (such as CVF6.5)?
Old   January 31, 2004, 16:44
Default Re: How to run Fluent on the background?[continued
Rob Hart
I'm not sure what the question is you're asking.
Maybe you want to use:
fluent 3d -i journal.jou
in your .bat file, in order to get fluent to go straight into the journal?
Rob
Old   January 31, 2004, 23:46
David
thank you. It is just what I want.Adding this parameter in the file "fluent.bat" could run all the Fluent actions on the background.Could you explain where I can find some guide of the use of these parameters?
Old   February 1, 2004, 05:40
Rob Hart
RTFM
Try node19.htm in the fluent online help. You may want to put a -gu into your bat file as well.
HTH
Rob
Old   February 1, 2004, 08:38
David
I have found this content in the Fluent help file.Thank you very much!
Thread Tools
Trackbacks are On
Parallel run in fluent for multiphase flow apurv FLUENT 2 August 3, 2011 19:44
Fluent can't run in parallel when hyper threading turning on. field FLUENT 0 May 5, 2011 07:41
How to run fluent in terminal? zjuADou FLUENT 7 July 20, 2005 09:36
how to generate a long annulus then run in FLUENT zhu chen Main CFD Forum 0 March 27, 2004 19:42
Help: run FLUENT bechmark SC FLUENT 1 July 11, 2003 04:56
