simple+Gambit+Heat transfer+mesh+problem+ha ha
Old   January 31, 2004, 10:51
Default simple+Gambit+Heat transfer+mesh+problem+ha ha
susan
Hi, I have a simple question.
How can I attach two volumes; where one of them is "solid" and the other is "fluid" (which passes thru the solid) ?
You know, my problem is like a "thick hot pipe" through which a "cold fluid" flows.
I mean shall I mesh both volumes first, and then try to attach them or vice-versa? __and how the attachment is done?
I am trying to get the temprature contour in both solid and fluid with FIDAP, but could only get the temperature contour in the SOLID not fluid.
Thanks in advance for a favorable reply.
Susan
Old   February 2, 2004, 04:40
Default Re: simple+Gambit+Heat transfer+mesh+problem+ha ha
Erwin
In gambit the approach is simple; just treat the solid volume as another fluid zone. You can separate the two zones from each other by 1) creating a cilinder volume with radius equal to your outside radius, and then 2) create a cilinder volume with radius equal to the inner radius, and finally 3) split the first volume with the second one. Mesh both volumes, and then set the fluid zone type of the solid volume as 'SOLID'.
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 05:43
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Conjugate heat transfer problem hvem10 FLUENT 2 October 29, 2009 17:31
Conjugate heat transfer problem with porous media piko Siemens 1 April 17, 2009 15:41
The problem with GAMBIT - using two mesh sizes. Owen FLUENT 2 June 22, 2005 05:16
