-   -   Volume Integral Averaging (http://www.cfd-online.com/Forums/fluent/32948-volume-integral-averaging.html)
ozgur February 2, 2004 07:19
I want to calculate the falling velocity of my drop in 3D VOF model. So far, I've created an iso-surface of volume frac. on the drop, and use surface integral panel to calculate the area-weighted average of Y velocity (the vertical coordinate) over the iso-surface. To be more accurate, I want to use volume integral panel, and do the same averaging over the complete drop volume. The problem is, there is no way to select particulary the volume of my drop (patched as volume frac.=1 of liquid phase), so that I can calculate an average over the all cells in my drop. I can only select the complete fluid zone in my domain. Does anyone have an idea how to fix this?
Thanks in advance
Erwin February 3, 2004 06:18
Re: Volume Integral Averaging
Here's the trick:
Go to the Adapt --> Isovalue panel and mark the drop region using your volume fraction criteria.
Now go to Grid --> Separate --> Cells and select 'Isovalue' in the 'Registers' panel and click the right fluid zone in the 'Zones' panel. Click on separate, this will now form a new cell zone that will contain your drop.
Now go back to your Volume integral panel, you can select this newly formed cell zone to perform your calculations.
ozgur February 3, 2004 07:52
Thanks for the idea. But I am not sure that I will be able to monitor the falling velocity of my moving drop continuously with that. I feel that I would need to do that repeatedly for any time t.
I'll try:)
Paola November 22, 2011 08:00
Hanging nodes problem!
Since I have activated the dynamic adaptation with the hanging node method, I cant do "separate cell", do you have any suggestions?
In my case, what I want to measure is the volumen of the droplet at a given instant, just once.
