fails saying “small gaps”
Old   February 2, 2004, 08:29
Default fails saying “small gaps”
Neser
I am a new user for FLUENT 6.0. My problem is:
When I let the Gambit mesh the entire operating room volume using Tgrid meshing, it fails. I increased the number of nodes, but it also fails saying "small gaps". I used the proximity surface-function at small edges (i.e. operating table thickness), but with sorry, the same fail and an error note "small gaps" appear.
I am asking for your help through this problem.
Old   February 2, 2004, 11:34
Default Re: fails saying “small gaps”
javier
This problem usually appear when the celd is not enough little to fill some part of the volume. But im not sure, it can be from other nature.
Old   February 2, 2004, 20:16
Anton
It can't grow tets because some of your geometry has very small gaps in it. Check your geometry to make sure you don't have any very small slivers or physical gaps. Under the faces geometry, choose connected, and click on "find smallest edge". Gambit will look for the smallest edge in your geometry. You may a small edge that you can't see. If your geometry is okay, then try breaking your volumes into smaller ones that you can mesh individually.
UNV mesh converter fails with patch jmf OpenFOAM Bugs 16 January 4, 2019 11:08
Grid Check Fails in Parallel Processing Mode askance Main CFD Forum 0 October 20, 2010 10:11
MPIRUN fails lfbarcelo OpenFOAM 3 March 29, 2010 07:41
CFX FAQ updated - my simulation fails to converge Glenn Horrocks CFX 0 September 1, 2007 07:33
SOR Fails Near Walls Chih-Wei Chiu Main CFD Forum 0 May 9, 2002 01:05
