bug in Fluent 6.1
Old   February 9, 2004, 18:58
Default bug in Fluent 6.1
hedonists
Is anybody happy with this: When you try to track trajectories of 30nm particles using DPM, they simply evaporate even for inert steel at 300K!
If you have a solution to this problem, please let me know.
The bug has been there for half a year. I don't know what the Fluent people are doing.
Old   February 10, 2004, 03:42
Default Re: bug in Fluent 6.1
Rob Hart
I suspect the reply you'll get is "it's not a bug it's a feature".
I've had other problems with the DPM model (maybe in 6.0 I don't remember) where droplets that really should have evaporated reach a diameter that's near enough to zero to make no difference, and cause all sorts of numerical problems. (i.e. overflow)
Rob
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 12:07
Polyhedra meshing in Fluent 6.1 mireis FLUENT 1 August 5, 2010 03:42
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 16:41
On Bug of Fluent 12.0 lzgwhy FLUENT 0 August 26, 2009 06:41
Error in Fluent? Specific Heat Bug SA FLUENT 0 February 18, 2008 01:14
