Viscous Grid Spacing Calculator
Old   February 9, 2004, 01:48
Default Viscous Grid Spacing Calculator
firedragon
hi,all
when grids are generated, this webpage maybe be helpful for you.that can estimat the normal spacing to be used in a viscous CFD grid.
can anyone tell what formula is used?
Old   February 9, 2004, 14:24
Default Re: Viscous Grid Spacing Calculator
James Date
I assume you mean the calculator at this web site!
http://geolab.larc.nasa.gov/APPS/YPlus/
See if you can make sense of this HTML/JAVA code for the Sutherland formula! Or find a good book which explains it somewhat!
Boundary-Layer Theory by Hermann Schlichting, et al (Hardcover - December 1999) should tell you what you need.
Regards James
Old   February 9, 2004, 20:47
firedragon
Thanks,James! sorry I forgot to write down the address of the website.however,the website that you offered is exactly what i meaning. I have the electronic edition book Boundary-Layer Theory by Hermann Schlichting,which was an old edition, translated by chinese. I will read it carefully. With kind regards
Old   February 10, 2004, 01:54
Chetan
Please can u send electronic edition book Boundary-Layer Theory by Hermann Schlichting. I need to read it. Or please send link from where I can Download it
Chetan Shah
chetan1373@hotmail.com
Old   February 10, 2004, 04:38
firedragon
I downloaded it witch is the chinese edition from the adress .
http://202.121.226.4/bookhtm/
http://202.121.226.4/bookhtm/search.asp?text=%B1%DF%BD%E7%B2%E3%C0%ED%C2%DB&item=%CA%E9%C3% FB&item0=ALL&Submit.x=7&Submit.y=13
if you are a user in the educational internet, i think you can download it.
Regards
[GAMBIT] Grid spacing calculator aamer ANSYS Meshing & Geometry 6 November 28, 2010 19:54
conjugateHeatFoam, grid spacing and gradient calculation benk OpenFOAM 1 May 5, 2010 16:06
Grid Spacing Calculation Zweeper ANSYS Meshing & Geometry 0 February 7, 2010 09:47
Using grid spacing calculator for laminar flow CH Main CFD Forum 0 November 5, 2006 00:02
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
