DO I NEED VISUAL C?
I HAVE TO INSTALL VISUAL C 6.0 FOR COMPILING THE UDF'S? BECAUSE NOW AFTER BUILDING I GET AN ERROR THAT THE SYSTEM CAN;T FIND THE FILE.
Re: DO I NEED VISUAL C?
You shouldn't need visual C if you are just using interpreted UDFs.
Rob |
If you're using FLUENT on Windows, you need Visual C++ to use compiled UDF's.
Hi :) ap |
I READ THE MAKE FILE AND I SAW THAT I NEED VISUAL C COMPILER. IS IT NECESSARY TO BE VISUAL C++?????? OR I CAN DO COMPILING WITH VISUAL C COMPILER??
THANKS FOR YOUR INFORMATION BET REGARDS |
Microsoft Visual C++ compiler is both a C and a C++ compiler.
Hi :) ap |
THANKS. I WISH I CAN HELP YOU IN YOUR FUTURE PROBLEMS!
