How to run Gambit in background
I want to run a bunch of .jou files in background. Is there a way I can do it without open gambit GUI?
Thanks. Jack |
Re: How to run Gambit in background
gambit (on unix at least) has the following options for running journal files.
-inp(utfile) journalfile (implies batch run and no gui) -init(file) journalfile (a journal file to run at startup of gui mode) -res(torejournal) file (implies batch run and no gui) |
Rob,
Have you tasted this? Or just refering what is in the manual. I tried to run GAMBIT once in the background but did not work. Solomon |
yes. I usually use unix, but especially for you, I have tried it under windows and it works just fine.
What exactly did you mean by "does not work"? Rob |
hello,Rob, I would like to try it under windows, thank you
regards, shancfd |
Rob,
I was once trying to run a journal file at the background to generate and mesh a geometry. The job script I created was not able to complete the job and was generating error messages which I do not remember now. At the time I was using remote machine so may be some installation or configuration issue might be the source of the problem. It is good that I heard from you it is working. I will try again. Thank You |
