pressure distribution in closed enclosure
Old   February 17, 2004, 12:33
Default pressure distribution in closed enclosure
Prasanth
hai, try to do this fluent for those using multiphas models. take an axisymmetric model of cylindrical tank. patch upper 20% with vapor and remaining will be liquid of any fluid like H2. then see the pressure before iterating, apply some heat flux on side wall and run...then for the very first iteration see the pressure..it will go into -ve values. bur for single phase fluid u wull find +ve values in pressure i hope some of u understand what i am saying please tell me what to do, any modification etc.
thanks Prasanth
Old   February 18, 2004, 05:33
Default Re: pressure distribution in closed enclosure
ozgur
Old   February 18, 2004, 05:36
ozgur
I also have the same problem with my multiphase calculation. I have negative static pressure values at the wake regions.
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 10:08
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
pressure distribution in water flow, differences in icoFoam and COMSOL deniggo OpenFOAM Running, Solving & CFD 14 September 30, 2010 03:48
plot pressure distribution on a section of 3D wing ROOZBEH FLUENT 3 April 21, 2008 03:30
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
