injection of fuel into tank filled with fuel
Old   February 15, 2004, 23:44
Default injection of fuel into tank filled with fuel
mujahid
i have some problems in simulating a fluid dynamics problem.. a tank is filled with fuel. then there is an injector injecting the same fuel but with a different density into the tank. the injector is immersed under the existing fuel level in the tank. we want to measure the distance the injector can inject the fuel into the tank filled with fuel of a different density. i have tried before this..but i can't use the same material but with 2 different density. how do i go about this problem??
i thank you in advance.
Old   February 19, 2004, 06:36
Default Re: injection of fuel into tank filled with fuel
mateus
Hi!
You should work with multiphase model. Probabilly mixture model will work good for you, and if not then try Euler multiphase model.
regards
MATEUS
UDF for fuel injection djokovic Fluent UDF and Scheme Programming 0 July 1, 2010 15:49
Injection of Fuel mayur FLUENT 5 November 11, 2009 12:25
partially filled tank under acceleration Jean-Gabriel CFX 6 June 9, 2009 18:29
partially filled fuel tank Deniz Boyacı FLUENT 0 March 9, 2009 02:03
fuel injection Johannes P. Siemens 6 February 19, 2009 08:45
