Help with Length Scale estimation/perforated plate |
February 19, 2004, 17:01 |
Hi! I am a beginner, and I need some help with length scales. What exactly are length scales? I saw an equation of l=0.07L. What is l? Also for a perforated plate, is L the thickness of the plate? What I understand is that downstream of the perforated plate I need to have cells of length around 7% of the thickness of the plate. Is this correct?
February 20, 2004, 06:30 |
Re: Help with Length Scale estimation/perforated p
Please this is urgent. I cannot believe nobody knows anything about length scales?!?!
February 20, 2004, 07:40 |
l is the turbulence length scale, related to the size of the large eddies in a turbulent flow.
For a fully developed duct flow, l is restricted by the duct size, L, typically, the hydraulic diameter. |
February 20, 2004, 09:24 |
Thanks Do you know anything about an obstruction in the flow like a perforated plate, what L would be in that case?
Display Modes | |
Turbulence length scale and integral length scale | rizhang | CFX | 2 | April 22, 2016 07:22 |
Integral Length Scale vs Turbulent Length Scale | Scott Nordsen | FLUENT | 2 | January 20, 2014 01:17 |
LES inlet length scale | f.neilson | Main CFD Forum | 0 | January 31, 2005 13:26 |
Characteristic Length Scale | Thomas P. Abraham | Main CFD Forum | 2 | April 20, 1999 17:16 |
