animation - playback - MPEG
I am using the play back option in animation pannel to write a MPEG file. But the results in MPEG files run too fast .. can some one suggest me a way to control this speed ?
thanks, charu |
Re: animation - playback - MPEG
sir
I am also facing the same problem. But some body suggested me to save each time frame pic as tiff format or some other picture format. After that use some animation sotware like Antechinus Animator to convert all the tiff files to mpeg format. Other than this, is anybody suggest any other better method. - Karthick |
Hi!
The method that you're using is probabbily the best option. Also the output file (movie) will have a much better quality if you make it manually (not directly from Fluent). Regards MATEUS |
