FLUENT import error
Old   February 23, 2004, 15:27
Default FLUENT import error
Tim P.
I hope someone has had a similar problem/message and can give me some advice. When I try and read a specific *.msh file FLUENT displays the following when it is building the grid: Warning: Number of nodes read (262790) does not match number referenced (262778). Resetting counter to match the number referenced. After that message it continues to load normally and I don't experience any problems while iterating. When I do a grid check, nothing reports out of the ordinary. A colleague tells me that I should be very concerned about this message - should I be?
Cheers, Tim.
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
