-   -   non-newtonian fluids (http://www.cfd-online.com/Forums/fluent/33124-non-newtonian-fluids.html)
mateus February 26, 2004 09:14
Hi!
I need to model a problem involoving non-newtonian fluid, but I can't find where do I have to put the viscosity data in fluent. The manual says that different models (non-newtonian Power law, carreau model, cross model and herschel-bulkley model) for non-newtonian fluids can be found in Materials-viscosity drop down list, but they are not there.
Help is greatelly appriciated.
mateus
ap February 26, 2004 13:51
Re: non-newtonian fluids
Just start FLUENT, go to the Materials panel. If you click on the drop down list for viscosity expression, you can see the models you're looking for.
Hi :)
ap
mateus February 27, 2004 04:14
Hi Ap!
Thanks for the fast responce. Strange thing. If you first define the materials (non-newtonian) and then read msh file it works. If you read a case file and then try to change the material properties to non-newtonian, the models are not there...
Thanks again!
MATEUS
ap February 27, 2004 08:10
FLUENT misteries :)
Good work
ap
ramone February 27, 2004 10:06
non-newtonian models are only avalaibles in laminar. If in your case file a turbulent model is selected, non-newtonian models will not be avalaible.
HVN February 27, 2004 10:40
If you want to use non-newtonian fluid with turbulence, you need to activate this option through command line in the fluent interface.
mateus February 28, 2004 07:37
Hi!
You're right! Figure this...you have to write... define/models/viscous/turbulence-expert/turb-non-newtonian? and then select yes. I don't get it why this kind of stuff isn't mentioned in manual.
Does enyone have some expirience with non-newtonian fluids (nnf). I have a free surface problem with nnf. I have to simulate a mixing prosess (only mixer in one fluid). I have a lot of expirience with VoF bun non with nnf. The simulation works fine if i use water, bud deverges with nnf. What turbulence model should be used here. If I work laminar it converges.
thanks for your help
MATEUS
