Incorrect Cp Value when I used Piecewise-Polynomial Profile
Old   August 14, 2023, 22:29
Question Incorrect Cp Value when I used Piecewise-Polynomial Profile
Liam Wan
CCFFDD is on a distinguished road
I'm trying to use the Piecewise-Polynomal Profile to define Cp of Air, there are 8 temperatue ranges I need to specify. However, from the fourth temperature range, the curve in the dialog box deviates from the curve I plotted in MATLAB, and negative values appear. I have double checked the input values and found no errors. Any ideas?
CCFFDD is offline   Reply With Quote
Old   August 15, 2023, 02:48
Liam Wan
Found the reason... The input value in FLUENT dialog box can only have less than 7 valid numbers, which leads to a huge rounding error.
fluent
Boundary Condition for rotating mesh w/ polynomial inlet profile PatrickCFD OpenFOAM Running, Solving & CFD 1 January 24, 2023 06:31
Fluent UDF - polynomial profile description mihnea333 FLUENT 0 February 26, 2021 03:19
Add piecewise polinomial material property EvaKn FLUENT 0 December 21, 2020 06:03
[swak4Foam] piecewise linear inlet profile: swak4foam? letzel OpenFOAM Community Contributions 5 July 3, 2014 15:43
enforce a periodic condition and polynomial profile in the spanwise direction... sawyer86 OpenFOAM Running, Solving & CFD 0 January 27, 2012 11:51
