March 4, 2004, 09:56 |
Negative angles of incidence
Hi everybody. I´m studying an airfoil in order to calculate lift and drag coefficients over a range of angles of incidence. The results are OK for the possitive ones, but I find some problems when calculating drag coefficients for the negative angles of incidence, like -1º and -2º. The airfoil is a supercritical one, and the boundary conditions are pressure far fiel and wall for the airfoil. Mach number is 0.76. The domain (far field) is big enough. Thanks for your help!!!!!!!
Display Modes | |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
blockMesh error ... | balkrishna | OpenFOAM Pre-Processing | 0 | August 17, 2010 02:39 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Contour plot with negative velocity | J | CFX | 11 | November 3, 2008 16:46 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
