Airapk-Results report
Old   March 10, 2004, 15:47
Default Airapk-Results report
Rajab
Hi all I am student using airpak for analysis of flow of contaminated air in the room. my problem are as follows:
1.By running steady state flow : I find out the mass flow in and out the room does not balance ..what can be a problem here..
2. I specified a certain flow and I need them to remain constatnt all the time but the result shows the specified flows have other value some less and other great than specified ones; what is wrong here
3.when checking the flow through walls ; I discovered that some cells on the wall there is flow through them, although the total mass flow throw the wall is remain zero as required, can this cause an problem in my analysis??
4. When checking the flow vectors I see that some opening allow flow in at the bottom of the opening and allow flow out at the top. but in reporting I get only one value which showing that the flow out or in; is this value a net value of the flow to that particular opening or and average one..?? so how can I balance the each component of the system..???
please I need your help on those prob;lem so I can go forward with my work
Rajab
OpenFOAM - Validation of Results Ahmed OpenFOAM Running, Solving & CFD 10 May 13, 2018 18:28
wind tunnel results vs fluent pixie Main CFD Forum 1 August 20, 2009 08:02
Velocity spots in openFoam results Valle OpenFOAM Running, Solving & CFD 4 August 19, 2009 05:53
How to plot a function over a time period? Cirion0000 CFX 4 July 18, 2009 12:48
CFX cylinder or sphere benchmark results Mel CFX 1 August 8, 2005 18:47
