axial velocity profile in swirling flow
Old   March 15, 2004, 08:39
Default axial velocity profile in swirling flow
David
I am simulating a swirling air flow in an unconfined environment (no wall BC) using the RSM model but when I check the axial velocity profiles, I get the highest velocities further downstream from the air flow inlet, which is obviously wrong.
I'm not sure whether i should use PRESTO or BODY FORCES and I hesitate between QUICK and SECOND ORDER for more accuracy.
I determine the operating pressure at the height where the air exits in the atmosphere but I wonder if i should indicate gravity acceleration.
Could you give me the procedure in order to get my axial velocity profile right?
thanks
regards
David
Steady pipe flow mean velocity higher than inlet velocity anita OpenFOAM Running, Solving & CFD 7 September 25, 2012 05:35
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
velocity of massless particles and velocity of flow field in same coordinate payam_IUST FLUENT 0 October 18, 2009 23:24
Fully developed flow profile icfd Main CFD Forum 3 May 20, 2009 22:21
Vel Profile in Y direction for 2-D flow devesh FLUENT 2 November 18, 2008 01:46
